finally pulled the trigger...so to speak.
I bought a 2010 road king classic in October. First HD. From the moment I left the parking lot I knew I wanted apes. Today I finally ordered 16" gorillas from Burly. Next week grips and levers and all the cables and whatnot. Any companies you all recommend for the cables and exactly what length I need to get?
Congrats! when I bought my RK, I liked it... when I put Apes on it.. I LOVED it.
16" yaffe's here...
as for cables, sorry, i dont know the lengths but i remember someone posting that you can buy kits based on the bars you bought. I have drag specialtiy cables (black). I didnt want the fancy ones!
16" yaffe's here...
The best thing to do is mock up the bars using weed whacker line to simulate the clutch cable and brake lines. That way you can measure and get exactly what you need, and you'll also get a visual of how the cables look, in case you want to change the routing, or add clamps, etc. That's the best thing to do, but most guys just want to order the bars and cables and lines at the same time, to minimize downtime. You should be able to get a recommendation from the bars manufacturer as to what length you need.
I won't install a set of bars using a forum recommendation for cable length. Done that in the past, and had to re-do it, so now I measure every time, unless I've used those bars previously. Even if someone says they've installed the same bars, it might not be to your standard.
And here's the bars. They just got here today.
Honestly im so new at this and its confusing. Are the wires inside the cable from the throttle? I guess what im asking is if I don internal wiring then I'll only have one cable outside the bars on each side, correct? If I understand correctly then heavier want to do the internal wiring.
Attachment 378302
Attachment 378302
