plasma rod woes
Old 05-12-2014 | 08:37 PM
streetg7's Avatar
streetg7
Angry plasma rod woes
tried to install plasma rods on my 2012 SG Thought I went by all instructions! I guess NOT! Right turn signal only is working! To make matters worse, backing the bike up to make room for my truck.....you guessed it! Didn't have the seat on or saddle bags, trying to put kick stand down...it flopped up & down I went! Of course bat wing up against wooden shelf...scratched! Damn! Then I couldn't pick it up! Had to get a tie down strap on the handle bar! Thanks for letting me vent!
Old 05-12-2014 | 10:39 PM
mkguitar's Avatar
mkguitar
I don't know how the plasma rods wire up, but I'm pretty good on how the wiring on the bike works...
maybe I can help you if you describe what you have done so far.
2.) check the ride like a pro 100 lb girl pick up a bagger on youtube.
you gotta be careful pulling up with the bars, they are NOT solid mount and can easy slip in the mount or deform the bushings & dent your tank
mike
Old 05-13-2014 | 06:32 AM
streetg7's Avatar
streetg7
going to ck all connections.....I have Ride like a pro.....bike was almost against the wall. Thanks for your comment...will keep posting!
Old 05-13-2014 | 08:30 AM
GriffinDenim13FLHX's Avatar
GriffinDenim13FLHX
Man that sucks! Glad you did not injure yourself. Hope you get those rods installed and hopefully you can buff out the scratch some.
Old 05-14-2014 | 08:32 AM
streetg7's Avatar
streetg7
cut off the "dual connector"....things went fine after that. Now I have turn signals & brake lights....good enough. Have not dealt with the scratch yet...took a ride instead
Jetblack3
09-04-2013 03:52 PM
Rick Lees
10-17-2011 02:59 PM
artz
07-24-2010 04:53 PM
sgnden
08-30-2009 11:41 AM
Quick Reply: plasma rod woes
