My 2001 RK clutch has over 50K miles and has started slipping. I've got SE-204 cams and 95" kit. I'm looking for recommendations for clutch pack kits. I'm not a street racer, so I'm not really wanting to spend big dollars, just a good reliable replacement for a reasonable price. What brand and a source please.
I just change mine out last week. I went to the se plates and spring. While it's a little stiff pulling the lever the clutch grabs like a sob,big big difference.
I'm running 101HP/107TQ on my 1990 clutch and have just installed a set of Barnet kevlar plates. If the basket is OK, do the same! But check your clutch adjustment first, as your clutch should have life left in it at that low mileage.
Greg
I would try and adjust it first. if that don't work then go back with what got you to 50k miles
