Motor head question
Unless you have a tuned intake tract (like the VRod) you can get horsepower improvements by lowering the resistance to air-flow on the intake side (works on the exhaust side too). Lots of folks using those A&N low restriction air filters on their motorcycles but you would never want to ride open (no filter). Particulates in the air are abrasive and damage your engine over time.
On the V-Rod the intake tract was designed by Porche Engineering Group -- one of only a few automobile manufactures that know how to create a tuned tract. The tract is sealed tightly and the two throttle bodies have velocity stacks of specific but differing dimensions all designed to time the intake from a high-pressure point at the front forks as the motorcycle moves through the air stream. This times the intake so one pulses pulls in the next and the intake tract becomes slightly pressurized (slightly over ambient). This is good for 6 HP on the Vrod. This can't be measured on a Dynometer because there is no high-pressure zone when the bike is sitting still. Many VRodders believe running "topless" (with the airbox open) provides some additional Horse Power (that REALLY can be measured on the Dyno but is actually a net loss).
20 k later I'd like to run her again but never have. I since put V&H headers too. One day this summer I'll have her run again.
I'd guess proper headwork will get ya 5-10tq and 10-15hp?? More compression and bigger cams would be some more. But ya start to really get into diminishing returns around there.
