abs/nonABS Bearings
05-08-2014, 03:36 PM
abs/nonABS Bearings
I have heard 2 different things. I have a 13 SG non ABS. I bought a set of ABS 14 rims. Can I just bolt them right up and go?
05-08-2014, 05:33 PM
You need to put non abs bearings in the front and rear wheel. The front abs bearing is the gray one as is the rear. There is one abs bearing per wheel.
05-08-2014, 05:47 PM
No you can't. The ABS bearing is not the same thickness as the non ABS bearing. The ABS bikes have a different spacer on that side to compensate.
David
05-08-2014, 08:12 PM
05-08-2014, 10:47 PM
Thx all, Yes, it is a 2014 touring wheel off of the SG.
05-08-2014, 11:32 PM
Quote:
Originally Posted by
glock221
If you had a way ( lathe ) to trim the spacer down to the same thickness as the abs sensor you could leave the abs bearings.
Jaftica
04-04-2019 10:19 PM
blackscootersociety
Wheels/Tires
01-16-2017 06:09 PM
Faststeel
01-28-2013 03:25 PM
01heritage
07-31-2012 10:26 PM
Bagger71
04-20-2012 10:59 AM
