Heated Grips retro fit an 2013 Ultra
Old 05-01-2014 | 03:02 PM
Sam D.'s Avatar
Sam D.
Default Heated Grips retro fit an 2013 Ultra
I just installed a Factory set of Heated Grips that came off a '13 Limited to my 2013 Ultra with no cutting or splicing...
1. First I removed the left grip and used a small diameter brass rod as a fish tape to install a piece of string thru my bar... I used another piece of brass rod to hook the string once I saw it at the passage hole in the middle of the bars inside the inner fairing...
On the left side under the Inner Fairing brace you will find a Pigtail connector for your Power & Ground source,,, you'll have to remove an endcap from the connector before you can Plug in the lead coming from your Left Heated Grip controller...
Then up behind the Right Inner Fairing brace you will find tucked down behind the Volt & Oil pressure gauge the other Pigtail coming off the harness to the Throttle By Wire connection, here you can plug in the connector with the Black & White wire connector coming from the heat controller that supplies the power to your throttle grip...
Then after you remove your Throttle Grip from the TBW sensor, remove the end cap from the sensor, you will see the two pin holes that the heat grip plugs into...
Hope this helps somebody out...
The following 2 users liked this post by Sam D.:
FLshovelhead (07-08-2018), Outlaw 692 (07-08-2018)
Old 05-01-2014 | 04:20 PM
aclass's Avatar
aclass
I just installed a set on my wife's Road King that had internal wiring. What a pain!
I was beginning to think they didn't work, but once you rev the bike up a bit, they start to get warm.
Old 07-08-2018 | 12:45 AM
Outlaw 692's Avatar
Outlaw 692
Stage IV
Thank you so much. I found it.
Cheers, Norm
Cosmic Razorback
2014-2023 Touring Models
12-10-2017 07:43 AM
eglide_rider
02-10-2016 10:53 PM
eglide_rider
02-10-2016 03:50 PM
JABMIKE
05-31-2015 06:02 PM
WooHaaSG
03-30-2015 01:03 PM
Quick Reply: Heated Grips retro fit an 2013 Ultra
