Torquing Rear Axle Nut
Old 05-01-2014 | 08:38 AM
Tucker99's Avatar
Tucker99
Default Torquing Rear Axle Nut
Had the new Metzelers mounted and went to install the wheels last night. Front went textbook. The rear axle nut requires 95-103 lbs torque. Following the book, adjusted the belt with 20 lbs torque on the axle nut and then torque to final spec. Could not figure a way of holding left side axle while torquing the axle nut. Since I only have 1-36mm socket, my only choice was...a 24" pipe wrench. My helper...the wife. I then had elusions of the the wife loosing grip and dinging the tins. I immediately aborted mission and decided to come here and gain wisdom from the elders. How do you guys do this chore?
Old 05-01-2014 | 08:53 AM
btsom's Avatar
btsom
With a second, appropriate wrench. After 60 pounds or so, you don't need to hold the opposite side, at least on my machine.
Old 05-01-2014 | 09:02 AM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
I usually tighten until I think I need the torque wrench, then the opposite side stays put.
Old 05-01-2014 | 09:05 AM
sanman4ever's Avatar
sanman4ever
Isn't there a 36mm in the HD saddlebag tool kit?
Old 05-01-2014 | 09:06 AM
sixguns's Avatar
sixguns
I bought a pair of axle nut wrenches from HD, makes rear wheel and belt maintenance hassle free.
Old 05-01-2014 | 09:08 AM
easycruzer's Avatar
easycruzer
Default tools
Check this tool out on Amazon- works like a champ. !
Jims 3rd Hand Axle Locker Tool 970
Old 05-01-2014 | 10:36 AM
bagman1's Avatar
bagman1
HD has one too, a little pricey but if youre by yourself its priceless!
Old 05-01-2014 | 12:10 PM
Takedown's Avatar
Takedown
Or you could just go to Sears and buy another 36mm socket. That's what I did.
Old 05-01-2014 | 12:24 PM
hardheaded's Avatar
hardheaded
the tool from JIM'S works good, it lets you dail in the belt and then keeps the axle in position while torquing the axle. it could be alittle beefer though.
Old 05-01-2014 | 12:26 PM
4shongo's Avatar
4shongo
I bought 2 of the long handle 36mm wrenches off Ebay for $19 each, made this job a piece of cake. 10 minutes and I was done. Took longer to get the bags off and my tools set up than to actual adjust the belt!!!
Quick Reply: Torquing Rear Axle Nut
