View Poll Results: A poll
Voters: 41. You may not vote on this poll
Spend $30 to fix PCIII Startup Delay?
I'm working on a plug-and-play solution to the PCIII startup delay problem. It's one thing to make something work on my own motorcycle. It's another to spend the money to make it plug-and-play and make sure it's ready for mass distribution. To make this worth my time, I would need to sell hundreds of these.
So, would you spend $30 on a black box that plugs into the PCIII that makes the startup problem go away?
RE: Spend $30 to fix PCIII Startup Delay?
Great idea, another piece that goes on the PCIII that attaches to the ECM...and what if this fails?
The start up issue is not life threatening...the hesitation from idle is!
Why isn't Dynojet solving the problem?
If you haven't bought a mapping system yet..go with a SERT and find a competent tuner..it's a two part solution.
