Torx size
04-29-2014, 07:16 PM
Torx size
Could someone tell me what size torx is needed for the SE compensator bolt Thank You
04-29-2014, 07:32 PM
13/16".......it's not a torx? Your asking about the bolt that holds the stock comp on? Correct?
04-29-2014, 07:36 PM
Asking about when I install the 42200064A kit The bolt that comes with it
04-29-2014, 07:42 PM
I'm looking at the 2014 parts & accessories catalog and the 2014 compensator is different. So I stand corrected and can't assist.
04-29-2014, 07:47 PM
T70 torx. Must be replaced every time the compensator is removed for service, torqued to 175 ft-lbs
04-29-2014, 07:51 PM
Quote:
Originally Posted by
flhxi-3
In the instructions, is that the tool that's listed as a T70 socket bit? Not sure if this is correct, but if it is, the instructions show a torque specification of 100 ft. lbs., loosen one-half turn, then torque to 175 ft-lbs. Under tools, it also says you'll need a primary drive locking tool.
http://www.harley-davidson.com/en_US...ts/-J05674.pdf
04-29-2014, 07:52 PM
Thanks for the help Just ordered a T70
04-29-2014, 07:54 PM
Do you have a torque wrench to torque to 175 ft/lbs?
04-29-2014, 09:41 PM
T70 is correct. Just finished mine tonight.
