Air Cleaner Help
Air Cleaner Help
Hey all. Last weekend I removed my air filter (K&N type) and proceeded to clean it and per the instructions. I've done this many times on my vehicles but this is the first time on my bike. Anyway, I must have been a bit over-zealous with the oil because I noticed yesterday that it's dripping out of the "football". I stuck my finger in there and came out with a red stub. I didn't think I applied that much but apparently I did.
So the question is, should I just clean it up for a couple weeks until the drip subsides or is it worrisome enough to warrant pulling the filter and do it all over again - without getting carried away with oil, of course. Suggestions please...
with the extra oil, it'll run a little rich. ( and the instructions make mention of this as i recall *)
you can remove the cover and pat it with a paper towel and wipe out the inside lip of the cover.
it'll be fine whether you wipe it or not.
mike
* I had to smog my 74 Blazer a few weeks ago, i made the mistake of cleaning and oiling the K&N a few days before testing and failed on hydrocarbons- I removed the filter and passed next round- reinstalled filter for the drive home. oops
mike
I am in a very dusty area, and i often hit dirt and gravel trails
when I last cleaned the filter, the amount of dust coming off of it was unbelievable, yet the filter had allowed good flow into the carb.
and since I keep stuff along time, some of my vehicles are running K&N's I bought close to 30 years ago.
they've paid off.
my gmc has 160,000 desert miles, I cleaned the intake and sensor a few months ago and there was very little schmutz on the maf sensor- i attribute that to the filtering
Mike
air cleaner help
After applying oil to the filter element I usually hold the filter in one hand and swing it hard toward the ground in the grass or the street. I keep rotating the filter element and swinging it until the excess oil stops flying off of the filter (usually takes about 5-6 swings).
