How do you change the oil in a bike with an oil cooler?.,,
04-26-2014 | 07:09 PM
04-26-2014 | 07:40 PM
So no one has suggested disconnecting the oil lines and hanging the bike up from the rear swing arm ?
04-26-2014 | 08:40 PM
Disconnect the oil line and then hang the bike by the swingarm....
04-26-2014 | 08:46 PM
Hanging by the swing arm will only get the oil out of the lines. You need to follow up with hanging by the forks to get the oil out of the cooler.
04-26-2014 | 08:48 PM
I was gonna suggest simply trading the bike in . . . . .
04-26-2014 | 08:50 PM
Pretend the oil cooler isn't even there.
04-26-2014 | 08:58 PM
Quote:
Originally Posted by
Greezey Rider
Drain the old oil, Change the filter, Add the new oil.....Go for a ride.
Don't overthink it, it's an oil change.
Lol..so very true.
04-26-2014 | 09:00 PM
The motor uses 4 quarts of oil. With a oil cooler you only change 3. I changed my oil today and when I change it next time I will use Scavenger. The book even says add only 3 quarts before starting. I have the scavenger just need the adapters for the touring bike. Only changing 3 quarts is not good enough for me. On top of that when the dealer does the oil change they charge you for 4 quarts of oil.
04-26-2014 | 09:06 PM
DGRF250
.....On top of that when the dealer does the oil change they charge you for 4 quarts of oil.
Yeah....But I'll bet they only put in 3.
