08 FLHT w/ ABS Front brake doesn't work-Lever feels Seized
So basically the front brake doesn't work and it has ABS. WE have tried the following- There is brake fluid in the lines and in the master cylinder. The front calipers are not seized. We have tried to bleed the lines but the brake handle is so stiff that I can not physically pull it to close. Brake fluid does trickle out some however. The abs light flashes when I start the bike and goes away after driving it for a few seconds. We have no clue what this can be. We through process of elimination have narrowed it down to the following- The front master brake cylinder-perhaps a valve is stuck inside it preventing it from opening/closing. Or is it maybe the ABS module. Any input and help is truly appreciated. Thank you guys
Plus the ABS light is functioning properly, probably not the ABS.
Sound like the ABS module, I don't think the abs light will show a stuck valve in the module. Think about it , how would the a stuck valve show up on a self check? I think the light only comes on if the electronics are not functioning as they should, after performing a self check.
either way, if the lever feels solid I suspect master cylinder.
I'm not sure how the self test works, I figured it operated the the valves as part of the test. If a valve was stuck in the ABS unit not allowing the lever to move, would it not be holding pressure on the caliper?
I,m still going with m/c. If the OP removes or just loosens the banjo bolt on the m/c and the lever can move then I'd move onto the ABS. If with the bajo loose the lever still dose not move I'd be rebuilding the m/c.
