09 Headpipe on a 12
adaptors
pretty sure ive seen post in here on adaptors for the different bung hole size, the wires may not be long enough though. on 09 the sensors are about 3 inches from the cylinder exhaust outlet. on the 12 both are by your right floor board guessing u may have to extend the wires and dont mix up the sensors if your 12 is like the 09s there is a difference in the front and rear sensor, wont run right if you swap them
davewear
12-23-2010 08:35 PM
