Help with lighting
Help with lighting
Can anyone suggest aftermarket auxillery [spot] lights that are close in brightness to the silverstar h4st headlamp.I have an 05 ultrawhich hasthe sealed beamtype spotswhich I believe are 27 watts. I'd like to replace them to match the brightness of the headlamp. Thanks in advance.
RE: Help with lighting
I put 55 watt H1 Silverstars in mine.You can get bulbs that match your headlight and even though they say they are "sealed beams" its just a rubber boot the you can slice threw and get to the bulbs. Then just use some RTV to reseal.
I think the stock bulbs were really sealed. You can tell just by looking for the filament in the bulb. The ones I have are these.http://www.harley-davidson.com/gma/g...bmLocale=en_US
HTHs
HTHs
