Khrome Werks +2 Sweepers - Cable Question
I am looking at purchasing these bars after doing some searching on the forum. From what I can tell, I will only need a longer clutch cable +3 to be safe.
My Question: I am wanting to to braided cables on clutch and brake, can someone point me in the direction of a set of cables to meet my needs? I'm not looking to bust the bank, so I don't care if they are HD brand cables or not
Andy advice or feedback would be greatly appreciated!
I'm in the process of installing Khrome Werks 2+2 wide sweepers on my wife's 06 Ultra. My first handle bar swap. I determined that the clutch, throttle and idle cables as well as the brake line all needed to be longer. After hours of painstaking searching on line, I determined the best option was LA Choppers cable and brake line kit for wide or pull back bars. Guessing by the part number, they should be 4 inches longer which will be perfect. I found and bought them from Dennis Kirk for I think it was $332 in black vinyl. Go to Dennis Kirk and take a look. LA Choppers makes kits for stock, wide or pull back and various sized apes. It's about the simplest solution I found to getting the right cables that all match. They should be delivered today so I'll see how I did.
Put the 2+2 bars on an 2011 Limited and went with a +4 clutch which was probably a bit longer than needed. I used a Magnum black braided cable which was probably nicer than needed. I also replaced the TBW unit with the SE unit which has no green plug but it did not appear to be any longer than stock wires. I did this to get rid of the green plug and because I had experienced a couple of "limp mode" issues earlier however I think they were related to throttle body connection. Brake line was tight but OK and all other wire lengths were fine. I left the wiring external for this swap. Dont think the curvature of this bar fits the inner fairing shape as well as the WO bars.
