2006 roadking custom overheating
I have a rkc 2006 that is having issues overheating at times. my bike is fine when moving on the highway but when i get in traffic in only about ten minutes it will start to run hot even hot enough to shut down a cilynder. I have reinhart true dualls. se stage1 air cleaner and pcIII. I am also running the pcIII map i downloaded from there site.does anyone have any suggestions? it will be much appreciated.
RE: 2006 roadking custom overheating
ORIGINAL: jtb4ever
I have the same setup ('06 RK Custom, PCIII, Stage 1, Rineharts).. I installed mself using the map provided by the manufacturer, and have had none of those issues. We had several 95-97 degree days last summer and the bike continued to perform fine.
What map did you select?
thanks everyone for your info. i am going to get it tuned today. is it worth it to tune the pcIII or just swap out for the sert?. yes gunrunner it does come back when i hit the gas. the map i am using is the only one they have i believe on the powercommander site is 807-220 does that sound like the one?. again gents i appreciate any info.
jpnelson1978
07-03-2006 08:13 PM
