Psi in shocks help
Psi in shocks help
Went on a nice ride today and it felt like the rear part of my bike was kinda banging in the rear when going over bumps so, I went to my local HD dealer and bought an air pump, when I checked it only had about 10 psi I think last time I put like 35psi now, I'm about 265lbs what is the correct psi for my weight?
30-35 should be right.
Wife @ 180 in riding gear runs 5-10, me on mu bike, @ 200 running 20, when SHE gets on mine BANG need more air. Tune the Air suspension to YOUR weight. When you add to the saddlebags H-D rear suspension is great, just needs a little fine tuning for your load.
Yes you can throw $$$ and make it better, but you do have the ability to tune what you have.
Dan B.
Central Ks.
Dan B.
Central Ks.
I know it's that I left it at work. Thanks for the info tho
I use a guideline of 10% of the total weight of rider, passenger and luggage. That will usually put you in the ball park, adjust up or down from there to suit your preference. I weigh 220. By the time I put on a jacket and other riding gear I will run between 25 to 30 lbs solo. Max air pressure is 50. Try varying pressures to see which suits your riding style best. Hope this was of some help.
