Derby Cover adapter on Air Cleaner?
Click here for the Screamin' Eagle Air Cleaner Trim Installation Kit with Rain Sock-28728-10.
"Add the open-element look to your Screamin' Eagle® Stage style Air Cleaner. This easy-to-install kit allows you to replace the traditional Original Equipment Air Cleaner cover with one of the custom inserts from one of the H-D® Decorative Collections."
You're right, my bad... the HD part number is either 29077-03 or 61400011 and the part (starfish?) by itself sells for $20 through your local HD parts counter. Drag sells a kit also for about $38. I've heard you can use a derby cover, but have not done so myself with the HD part. The Drag kit says, "Matches the five-bolt style of OEM derby cover". Can't see them being any different. HTH!
Here is my previous '04 RK Custom. I had an SE Air Cleaner on it that I simply removed the stock cover and the HD air cleaner inserts fit perfectly over the top of the air cleaner element and bolt exactly where the stock air cleaner would have...
As far as Arlen Ness, I have their Big Sucker Derby that actually accommodates any derby cover. I don't think they have an adapter as this is actually a whole differently shaped element/part from their regular big sucker.
Hope that helps a little!
E
E
