This is probably really stupid, but when I set my cruise control and then have the need to increase speed and set it again, it always goes back to the original setting. Is this normal operation? Thanks!
Think that sounds normal, you can bump the speed with the toggle/switch (forward to increase/back to decrease). Or disengage the cruise control and set it again for the speed you want.
Is there any chance you are hitting "resume" instead of "set"?
If you bump the switch on the right side forward, it should increase the speed + hold the new setting. Pulling it back slows it down + changes the setting. How are you doing it?
