I have a 2013 roadking..will i def need longer brake n clutch cables when going from stock to 12in mini apes??
You will have to extend the wires. Clutch and brake will be fine. You may have to reroute the brake line on the inside of the triple tree to give you a little slack...I just did another King last night with this exact same set up...
Edited to add: Those are 12.5 Wild ones in my signature pic with stock brake and clutch cables...I have since went to 14s.
