License Plate Mudflap, like the idea?
I have been searching for ways to move the license plate down or to the side and clear up the rear fender. I noticed I could mount it below the fender and it might look good.
I just slipped an old license plate in there behind the trim bracket to get the idea and I think I will try and make it work. Just make a little frame and work out a light.
[IMG][/IMG]
[IMG][/IMG]
You can get a set of plate bolts with leds for about $15, wire them into a run circuit under the taillight. there will be unused pins which on other models might be used for the fender tip light.
a bunch of us with detachable tourpaks use a FLHR signal bar and plate mount
do a quick DMV check and see if a minimum height is set for your State.
the last thing you probably want is an easy excuse to be pulled over.
mike
mike
