Battery replace question?
no, just the radio clock will need reset.
if you want auto parts stores sell a memory keeper adapter that plugs into the lighter socket and uses a 9 volt battery.
but I think with most year Harleys you'd need the ign switch at acc for it to pass current.
if you think your current battery is duff, replace asap. a dead battery can harm the charging system
battery tips.
most of us use the big crank for about $100.
even though new, charge a new battery overnight before using it, that will extend it's life.
when removing the old battery, you have to move the ECM, just loosen the bolts, flip it over on the rear fender, use a towel
remove the negative cable first ( that way if your wrench contacts the frame when removing the positive, you won't shoot sparks all over)
the strap which runs under the battery may be rubbed through, do not trust it to support the weight of the battery...don't dent your tank or drop it on your foot.
check the condition of the battery cables, nice and clean and tight at the other end?
new battery in, hook up positive cable first, negative second
mike
battery tips.
mike
battery tips.
mike
battery tips.
mike
battery tips.
mike
battery tips.
mike
