Progressive 970 shocks?
Will they fit on a 2013 FLHTK with the hard saddlebags?? Also what length should I be looking at if I want to maintain the stock height?
2013 Ultra ltd Anniv.
stage 4 Kit
se259 cam,58mm throttle body,heavier clutch spring,10.5:1 pistons, super tuner pro, stage1 air cleaner, Screamin eagle street cannon exhaust
stage 4 Kit
Last edited by helenmcr1@gmail.com; 08-24-2014 at 08:21 AM. Reason: Bike Description
The only thing JRI or Ohlins changes at the factory is the external spring based on weight and type of riding. The internals are the same on each model of shock. This is directly from both companies. Both can be rebuilt, at your cost. I think the Progressives come with a lifetime warranty and they rebuild for free. Need to double check that.
