Tour pak lighting ideas needed
My bike has a tour pak wire harness/plug already on it. Don't think yours does. If it does look under the left side cover by the right lower corner of the fuse block and it will be zip tied to the antenna wire.
http://www.ebay.com/itm/like/110782756227?lpid=82
Nice idea for the lid too.
I use the cheap eBay version of the cvo led wrap, its run/brake with the center lights as the brake. Side by side with my buddies 2012 cvo ultra they are actually brighter, but the new 2014 tour pack lights are a little brighter. Also added eBay tinted LED side marker lights and a Harley air wing LED in the luggage rack that is run/brake. On the back of the bike I also have the Harley tri bar run/brake light and added custom dynamic red led lights in place of the stock bulbs. I can be seen easily! All the plugs to wire the lights for a tour pack are zip tied behind the fuse panel under the side skirt.
http://www.ebay.com/itm/Directed-860...8a09a9&vxp=mtr
Uncle Larry (02-01-2020)
