Tranny lube
You have opened the proverbial "Can of Worms" on opinionated oil usage threads. you will get 400+ different opinions on this. So, for opinion number one, here's mine.
Yes, motor oil can be used in a tranny. However, I do not think it protects as well as an extreme pressure gear lube. That being said, I will not put motor oil in a gearbox.
But if your hell bent on using Amsoil in your bike, my recommendation would be the 20w-50 in the engine and primary, and an Amsoil gear lube in the tranny.
If your owners manual states to use gear oil, I would not use 20w-50 Motor oil, period. After the warranty is up then use what you want, but I still would retain the use of a gear oil.
I use Amsoil in the crank. Formula + in the primary and Redline in the tranny. I agree that a gear oil should be used in the gearbox. The logic is too clear to ignore. There are higher shearing forces in the gearbox with longer change intervals and no combustion taking place.
Redline is very sticky and is the color of Pepto Bismol which makes it easier to read on the dipstick.
Something to know is that gear oil is not measured on the same scale as motor oil.
