Road Glide/Ultra rear turn signal bar.
Should be simple bolt on. I just did this on my 08 using a RK bar from an 09 to move the plate down. I went up between the tire/fender from below....a bit of a PIA because it's tight...should be a little easier on a lift. Some guys go through the holes behind the tail light housing. Take your time, just make sure the bar is straight when you tighten.
hdmike1522
Electrical/Lighting/Alarm
09-04-2016 06:14 AM
