fuel question
fuel question
I have a 2009 Ultra Classic. I just installed a K&N RK-3939 air cleaner system yesterday. I went for a 300 mile ride today and bike ran fine. Pulled the plugs and they look great. If I put a set of slip on mufflers , will I need to do any fuel mapping or will I be ok ? I did nothing but ride after the K&N was installed.
Swap into different exhaust, you will, indeed, need to do something.
there isn't a bike out there that doesn't need a tuner to correct the EPA mandated lean condition that is known as "factory tune"
Add more air to the mix by a high flow air cleaner, and you are making it leaner, change the exhaust also requires "fattening it up" IMHO.
Now as for what tuner.... that is for another thread.... unless you want this to go 400 posts long
I would recommend you do some homework and research. Lot's of good info here on the forum (a whole lot) on tuner options and a ton of opinions. It really comes down to what you want out of your bike. Some are simple plug and play and others are very sophisticated....
My opinion, FWIW....if you go to the dealer, you will likely come back with a lighter wallet and the dreaded stage 1 download.....and longing for more.
Do some searching. Lots of info here, but it really comes down to what your goals are for the bike. If stage 1 is it, the inline fields type richening device may be fine. Simple plug and play, inexpensive but limited in what you can do. Higher end tuners such as Powervision allow for very detailed tuning of dozens of parameters. Expensive, but necessary for more extensive engine mods. HD has downloads for various options as well, but pay every time you do another set of upgrades. Other folks will probably offer up other options
