Dam it; Janet; Cam it!
Finishing up stage one on my 07 FLHRC this week. Going to cam it next. I'm looking to fuel Motto for cams. I can't decide between the Wood 222, or 555.
Any thought on these two choices, or other cam options would be appreciated. Ordering my tuner thru FM, so thought I'djust make it a package.
All I can offer is do some research and make sure your cams compliment the rest of the motor.
If you choose a cam better suited for a bigger inch motor or higher compression and head work and stick them in your stock motor you might be happy until someone with a cam matched to their setup hands you your butt.
Do a bit of talking with the experts, I actually spent a little time talking with the folks at Andrews about cam selection and learned some good stuff and helped me make a better choice.
I would suggest call bob wood at woods cams he will tell you which ones for what you want to do and to fit your riding style just put in 222 bob suggested them and so far good also like what was said before check out fuel moto and look at dyno test results good luck let us know what you went with
