EZ up center stand
Never used a center stand until I had one of the EZ Up's installed in Daytona. Once they got it installed (took a whole 5 min's) the installer showed me how to use it both seated and standing next to the bike. So far I've used it just like bbs15 and have had no issues putting it on the center stand.
One thing you may want to check is the shocks. From what I was told if the shocks are to low you may have a problem getting it up on the stand.
Tips for solving common problems:
If you have difficulty getting the bike up on the stand, check the following: the bike must be in neutral; the wheel should be straight forward and not cocked; do not hold the front brake lever; and make sure you have 30 lb or more air pressure in the rear suspension. Also when pushing down on the foot lever, lift your weight up off of the seat so you are not trying to lift the bike and yourself. These are the most common problems we encounter.
Having ridden bikes for over 40 years, most of them fitted with centre-stands, I have never tried to put one of them on it while sitting on the bike! You're doing it the right way by getting off first!
The ez up Center stand is meant to be applied from the riding position. It is actually easier from this position.
I have to chime in and say while sitting on the bike. I find standing next to it harder.
Practice both ways and do what feels right for you.
http://www.wheeldock.com/page/home/r...r-stand-videos
The knockoff you DO need to get off the bike and put it on the stand..
