03 Electra Glide
Evening guys..., I am looking to clear something up. I was told that the key fobs have a theft device installed. If it gets so far away from the bike the bike will stall. Is it designed to shut the bike down if someone takes off on the bike? If so, does the alarm have to be engaged for this feature to work. This is my first Harley...., not sure if my partners joking me or not. This all came about on one day I almost left home without my key fob. The joke was " your bike would have shut down" Thought I would ask..., this is how the Low Jack work on my truck.
not on the later models...our bikes can start and run without the fob...
but when stopped cannot be restarted (unless the PIN is entered by the owner).
a few stories of Guys who started up in the garage and headed out, leaving the keys/fob on a hook...and than at the first gas stop couldn't restart
mike
mike
Thanks.., I guess I will look in to setting a PIN in case I need it one day. Not sure if the previous owner had one set.
mike
mike
I don't think your earlier model is set up thataway. My 2006 FLHX is not...I believe that came in for 2007 or 2008 models. Check your owners manual. If you didn't get one, find one on eBay or see if the dealer can get it. Also get a service manual if you intend to wrench on it, and I mean even to change the oil.
If you have an 03 and have security your fob has a button in the middle of it you have to press for a couple seconds to arm the system. Turn signals flash a couple time to confirm and a key symbol will continually flash on the dash. To disarm you hit the button twice in a couple seconds.
