GPS power adapter ?
Old 03-20-2014 | 04:28 PM
472viper's Avatar
472viper
Default GPS power adapter ?
I know this has been addressed before, I apologise but I can't seem to find it.
Looking for a 12v adapter that I can plug into cig lighter on Street Glide that does not hit tank when bars are turned.
I thought somebody had a 90 degree adapter or some kind of fix.
Old 03-20-2014 | 04:38 PM
danzio's Avatar
danzio
Old 03-20-2014 | 04:40 PM
472viper's Avatar
472viper
That is not at all what I had in mind.....................it's 100 times better !!!
Thanks !
Old 03-20-2014 | 06:00 PM
Justin Kelly's Avatar
Justin Kelly
I have seen these at Casey General stores for around $5
Old 03-20-2014 | 07:08 PM
472viper's Avatar
472viper
I'll check it out, thanks.
Old 03-21-2014 | 08:54 AM
zdrifter's Avatar
zdrifter
As an alternate to the cig lighter plug, you might try this: http://batterytender.com/usb-charger-qdc.html .
A much more reliable connection and altho it is currently out of stock it may be worth waiting for. Also be sure what you get has the amp rating you need. Many USB adapter/chargers just don't put out enough amps. Cheers
Old 03-21-2014 | 09:37 AM
14 FLHX's Avatar
14 FLHX
Old 05-02-2014 | 01:39 PM
wuaname's Avatar
wuaname
Wow, that's a great idea since I have the battery tender cable on it already... I just checked those links and seems they are all out of stock.. Wonder if not being manufactured any more
Old 05-02-2014 | 03:10 PM
themensh's Avatar
themensh
Depending on your GPS, you may not be able to use your DATA cable except for charging? I know on my Garmin, I can't use the GPS in a car using the cable that I attach the GPS to my PC for downloading.
There are companies that make replacment cables.
Chuck
Old 05-02-2014 | 03:22 PM
14 FLHX's Avatar
14 FLHX
these place's has them in stock.
http://www.cruisercustomizing.com/ba...rt/BT-081-0158
https://www.denniskirk.com/battery-t...prd/283934.sku
http://www.ebay.com/itm/Deltran-Batt...-/271429682772
Quick Reply: GPS power adapter ?
