Did you drop the front end? If so, how much and what suspension did you use?
dropped it 1" using the progressive lowering kit...I also use the SE heavy duty fork oil...not sure if it's 20 or 30wt...didnt say on the bottle...but i haven't had any issues bottoming out or anything
How many c clips did you use and how much do you weigh?
i used 1 c clip on each side.....i weigh 170 on average...but I've also ridden this bike 2 up and still no issues...motor is built to a 107" as well if that helps any
Thanks so much for your input man. Much appreciated. I'm planning on goin 23" in about a week...unfortunately, raking isn't in my budget at the moment. So, no rake. I have monotubes that I'll use with the 1" drop and try 3 c clips cuz I only weigh 160 -165 on a good day.
