Best speakers without adding amp?
Did a search about speakers and every time someone asks about which are the best there are answers like you have to add an amp and do this and that to get the best sounds and don't bother adding just speakers. Well if I want the best sound I would stay home and listen to my home stereo. Going down the road at 50-70 mph nothing will sound perfect.
I just want to upgrade the speakers for about $100 to $150 to get a little better (not perfect) sound. All agree the OEM speakers are not that good and can use a little boost.
Looking for 2ohm Hawg Wired or Hogtunes or whatever you have to recommend and I am not going to add an amp.
Thanks in advance.
Thanks in advance.
The reason you hear that is because it's true. Not to get perfect sound, but just to get decent sound. The advice comes from guys that have already spent the money you're about to spend and then turned around and spent it again to get an amp and some nice 6.5" speakers.
If you've got yourself convinced that just replacing the factory speakers with some Hawg Wired ones will satisfy you, I've got some sitting on the shelf and would make you a deal.
Guys aren't trying to be audio elitists, it's just a fact that tooling down the road at 70 mph it's nice to have sound loud and clear vs. loud and distorted. The sound isn't studio perfect by any stretch of the imagination, but I'd consider it the bare minimum and what should have come from the factory in the first place.
I agree, spending money trying to get studio quality sound on a bike is nuts. Just think about the advice given by those that have been where you're at. We all thought the same thing you're thinking right now.
Sound quality is relative. I went with biketronics 6.5" speaker and amp kit, and it is loud and clear, but it's still not great sounding compared to a car audio system of similar equipment. The HK radio is a big part of the problem, it doesn't produce very clean sound, has crappy equalizer options, among other things. and the only good solution is to replace it.
i put in mm651s in at the end of the season last year and while they sounded tons better. i just bought the pbr300x2 to crank em up this year. nothing wrong with doing it in stages.
hardest part is that if your not amping them you need to stick with closer to a 2 ohm speaker which there is less selection of. if you are amping them immediately your choices open up exponentially as they will get enough power regardless.
Should note that my speakers are 4ohm, as required with the older radios. Not sure if that has much impact or not. Last season I also tied in Sirius XM, as I tired of messing with my MP3 player.
Thanks in advance.
Thanks in advance.
