2 into 1 slip on and dual slip ons difference?
I have one and only one Vance and Hines Hi-output slip on for the left side of duals. I have Vance and Hines power duals for head pipes. The question that I have for you guys is will the 2 into 1 High output slip on from V+H fit on the right side of my duals ? I think the length may be an issue. Have a chance to get a deal on a 2 into 1 slip on and just wondering if it will work. Thanks for any help...
The 2 into 1 slip on made for the 2010 touring bikes is a different length and comes with a offset bracket to make up for the length, not sure if that helps you or not but I just installed one and thought I might put that out there. I also used a 2010 headpipe but it seemed to be the same length as a 13.
