Notices
Klock werks flare with apes
Old 03-14-2014, 04:16 PM
toprat's Avatar
toprat
toprat is offline
Default Klock werks flare with apes
Anyone rockin the 6.5 flare with a set of apes? I just ordered the flare windshield to try, but I like my apes push forward. Wondering if I'm gonna have to pull the bars back some to accommodate the bends in the flare.
Post up some pics please?
Old 03-14-2014, 04:57 PM
lowprofile2000's Avatar
lowprofile2000
lowprofile2000 is offline
I don't recall if mine is the 6.5 or 8.5 but it works with my apes... I will try and confirm tonight.
Old 03-14-2014, 07:28 PM
cbennett1's Avatar
cbennett1
cbennett1 is offline
Not sure what kind of bars you have, but the KW Flare did not work out for me. I loved the windshield when I had my stock bars, but I then swapped to 12" monkey bars and the bars had to be pulled back way too much for me. I ended up with a windsplitter even though I really like the flare better.. Take care
Old 03-14-2014, 10:15 PM
BQsHX's Avatar
BQsHX
BQsHX is offline
You'll have to notch the flare a bit to clear 14" apes. A dremel with sanding barrel and some patience is all you need. I don't run my 6.5" KW anymore.
Old 03-14-2014, 11:58 PM
decencyxdefied's Avatar
decencyxdefied
decencyxdefied is offline
my 14 mayhems r right at the shield.. any taller and they would hit unless u pull the bars back.. I asked the same question a few months ago.. I don't like the way it looks anyway..
Old 03-15-2014, 07:41 AM
sanman4ever's Avatar
sanman4ever
sanman4ever is offline
6.5 klock werks didn't work with my 12" Monkey Bars
Old 03-15-2014, 11:39 AM
dugan's Avatar
dugan
dugan is offline
The Klock Werks didn't work well for my 10" Yaffe MBB either. I have long arms so I pushed the bars forward as far as I could. KW shield was touching bars and didn't look good. Went to a LRS 7".
Old 03-15-2014, 01:27 PM
sanman4ever
Klock Werks is over rated anyway in my opinion. If you don't have the height just right and have to look through the recurve it's like a bad acid trip.
Old 03-15-2014, 01:36 PM
decencyxdefied
haha yes been there done that
Old 03-15-2014, 02:33 PM
Cowboy Rob's Avatar
Cowboy Rob
Cowboy Rob is offline
Big Kahuna HDF Member
Received 2,573 Likes on 1,497 Posts
unless your bars are pulled way back,mine weren't.
Quick Reply: Klock werks flare with apes
