fairly dumb braided fuel line question
OK. My tank has been off my 06 RK since October. But a new braided fuel line on it and all was easy on the tank end of the line. Now, here is the stupid part: where does the other end connect? I can't remember and the service manual doesn't have a good diagram to help me.
Thanks for your help in advance.
There are two (2) possible fuel lines that come off the tank.
- one is a crossover line that connects the two 'sides' of the tank. That goes in the front and installs on the 2 tubes that stick out of the tank and have 90-degree bends towards each other. That needs to be installed while the tank is on the bike, as it is routed below the backbone of the frame.
- the other fuel line comes off of the petcock (or EFI valve) and is routed to the carb (or fuel injector for EFI).
Hope this helps.
Hope this helps.
