Yet another bars question
Background: I'm 6'5" and ride a 2014 FLHTK. I'm tired of hitting my knees with the ends of the bars on full lock turns.
So, I'm doing some research about changing the bars. There are so many aftermarket bar makers that my head starts to spin. I've been looking at a couple of replacement bars from the MoCo. The Tallboy Touring Handlebar-56184-08 is a 10" bar and the Chrome Bat Wing Mini-Ape Handlebar-57474-11 is a 12" bar. I don't want to go higher than that.
My question is about the description for those 2 bars. The 12" bar says "not for use with heated hand grips" but the 10" does not have that disclaimer. What is the reasoning behind not using heated grips on the higher bars? Is it because they are not "behind" the fairing while the 10" bars are? If that's the only reason, I'm going with the 12's anyway.
I'm spoiled and I'm not giving up my heated grips. They are definitely worthy on a 20 degree ride...
TIA,
Diggs
TIA,
Diggs
I've been researching this lately as well. Best answer I've found about the heated grips is that the stock wiring won't reach. I've seen where guys used the HD 12 batwing apes with all stock wiring, brake lines and cables with only rerouting required. The only wiring that would get extended would be the heated grips if I understand correctly. A lot of guys not using the heated grips just cut the green plug off for easier wiring
Hmmm
Well, since the instructions for the heated grips I want to upgrade to shows a cut of one of the wires (and crimping a different connector) then I don't see why the wires could not be extended, if indeed that is the reason the 12's say no to heated grips.
I think I'm going to place an order with Kutter for the grips and bars.
We shall see if I die a horrible, flaming death or not.
Diggs
Diggs
