'12 RG with FM 117 has no spark
Hello HD forums, I am a new member but have viewed this site for quite some time, stealing ideas from you guys! Anyway, I just got my FM 117 together and attempted to start it and come to find out I have no spark. I have 200 psi in each cylinder w/ ACR's disconnected, I can smell fuel in the exhaust and on the plugs, but am missing spark. The bike is a 2012 RG, FM 117, Rev Perf. bottom end, SE 58mm throttle body, HPI 5.3's Drago's Dragula 2-1, Power Vision and a couple other things, but they shouldn't matter for this issue I wouldn't think. I do have RPM's reading on my tach and PV so I believe the CKP is ok. I have checked to make sure all plugs are plugged in and nothing is pinched. I do get oil pressure, the bike is in neutral, run switch is on, I believe most the silly stuff is correct. I have 4.89v feeding the CKP and 2.5v coming out while cranking. There is a strong 12v feeding the coil. I checked for spark with the plugs in w/ an inline tester, as they don't spark well or at all if not installed. I also checked to make sure the TBW from the grip & the TMAP were functioning on the PV as well. The TB actuator did have a couple bad wires in it, but none touching each other, that has been fixed but did not solve this problem. I am not seeing any codes either.
Any help would be greatly appreciated as I am probably missing something simple.
Thank you, sorry for the long post from a new guy.
I got it figured out! sporacer, you were correct, and I thought I had that all squared away. I was clear on my rear valve cover but touching on my front cylinder on the intake valve, I hadn't cleaned out enough material and it was still touching it. I have only gotten a hundred miles on it today but it seems to be pretty impressive. Thank you all for all your help.
wildbillshdsoftail
08-10-2009 09:45 PM
