red key light
red key light
2005 ultra,,is the security light suposed t be on all the time?? or just when you fire up the bike ?? i think it has all ways gone out but i noticed today on the way to work that it was on all the time.. can still set the stystm. and it seems to work,, if not suposed to be on how do you reset it ??
thanks
thanks
i did led turns frnt and rear, led tail,, cust.dyn. tour pac module, led equlizer under the seat all plug and play stuff,, but the light is on all the time now ,, still flashes when activated,, any way to get it to go out?? mabe disconect the batt. ???
if you have LED lights without a load equalizer, the red key light will come on the first time you use your turn signals, and it will stay on until you shut the bike off. If I did not use my turn signals the red key would not come on. At least thats what I found out on my 11 SG after I installed Custom Dynamics LED turn signals. Installed the equalizer and problem was solved.
http://www.ebay.com/itm/Equalizer-Ha...5ae666&vxp=mtr
do i need to wire in one of the inline versions also??
dont like them cuz they get real hot so that is why i bought this one.
thanks mike
thanks again mike
