PCV map
PCV map
I just changed my headpipe from power duals to dresser duals. I know I need to change my map on my power commander. Do any y'all have a map for:
2010 street glide
Stock 96"
Stock cams
Screaming eagle stage 1 a/c
Dresser duals
Cfr mufflers
If so, can you email you PM me or email me the map! Thanks!!!
2010 street glide
Stock 96"
Stock cams
Dresser duals
Cfr mufflers
2010 street glide
Stock 96"
Stock cams
Dresser duals
Cfr mufflers
2010 street glide
Stock 96"
Stock cams
Dresser duals
Cfr mufflers
http://www.powercommander.com/powerc...mmander_v.aspx
Dont have a specific map on my computer but there are TONS of maps that will work for that on the Power Commander website. Details here...
I used about 4 or 5 from the site until I found one that worked for me. Everyone will have a different map because we live in different climates, elevations, etc. My advice is to try a few of them until you find one you like.
2010 street glide
Stock 96"
Stock cams
Dresser duals
Cfr mufflers
2010 street glide
Stock 96"
Stock cams
Dresser duals
Cfr mufflers
Here are a couple that should work. Both should work, the one marked 2013 is little more aggressive and the other should run just as well or real close, but will get better mileage. Both are aggressive on stopping the decel pop as most of the true duals tend to decel pop. Have any questions let me know.
2010 street glide
Stock 96"
Stock cams
Dresser duals
Cfr mufflers
2010 street glide
Stock 96"
Stock cams
Dresser duals
Cfr mufflers
http://www.powercommander.com/powerc...dl=313&yr=2011
luisfernyserrano@yahoo.com
05-11-2011 04:55 PM
