WinPV--no Pro user mode
When using my WinPV software, I can't select the Pro user mode. Normal mode is the only choice. I've used the Pro mode before, what gives?
When I "Get Tune" from the PV, the file loads fine but the title is displayed as "untitled.pvt" and I'd like it to display the title that I named it on the PV. The name shows up properly on the PV. If I "Open Tune" from WinPV the title shows up correctly. I thought maybe if I could get to Pro mode I could make it happen.
Any help is appreciated.
Thanks
Thanks
Thanks
Thanks
OK, thanks for the help. I guess I'm a little slow with this stuff. I reckon I've been doing this backwards as I've used "Get Tune" and made changes to the tune then saved it to WinPV then used "Send Tune" to get it back to the PV.
If I "Open" a tune I can make changes and save it back to itself then send it to the PV. That way I'll be looking at the tune title to insure myself that I'm modifying the right tune.
As far as the Pro mode, I updated my WinPV tonight and I guess that's how I lost the Pro mode, I really don't know.
Anyway, the main reason I was asking is that I was changing speedometer and mpg cals on all my tunes and I was having trouble remembering which tune I was modifying.
I appreciate your feedback.
I have played with the Speedo and with stock gearing 2206 was factory and need 2262 for correction. The MPG adjustment I wound up with 1870 and it is closer, but lots of variables. I have been using the instant mpg more than trip average to get an idea what changes I make if they work. I have a 2010 FLHTK, but shouldn't be that different.
My stock speedo was 2140. I changed it to 2191 and it's dead on between 60 and 70 mph. If I ride slower than that I know I'll be going a little slower than the indicated speed and if I ride faster than that I may be going a little faster than indicated but it won't matter too much as I'll be subject to getting a ticket anyway.
The stock mpg was 1989. I adjusted it to 1862 and when I checked it today, the PV said 41.4 mpg and the calculator said 41.8 so I may bump it up a few points. As you said, lots of variables.
gearheadfmc
09-29-2018 07:37 PM
