Too many connectors on battery?
I need a better solution than all these wires hooked up to my battery, its starting to look pretty messy and is a real pain hooking all these connectors up then trying to install battery cover. Currently have a riders and passengers heated connectors and air horn connecters. Is there some kind of terminal extension made that I can connect to instead of having all these going to the same battery posts? I had to trim some of the cover away to give the terminals room allready.
I don't know if it would solve your problem or not, But my last bike before my RK was a VTX. When I had it I saw a mod on the VTX forum to make/mount a small fuse block for any accessories separately. It eliminated all of the additional wires going to the battery. I used a simple 6 fuse block from an auto parts store. I also wired a relay in to only power the box when the ignition was on. The only issue you'd have is if you can find the space for it.
You do realize you should have two connectors for each post. One on top and one on the side.
I also run all of the positive wires going to the battery into one large o-ring connector and attach it to the side post. Same with the negative wires.
The fuse block idea is a good one if you can find a suitable location.
