How can I tighten the slot for a fuse? I was troubleshooting my intermittent heatedgrips and it "appears" they start working again after I remove andreinstall the accessory fuse (happened twice) on my 2012 flhtk. I noticed this fuse is very lose fittingcompared to the other fuses and I've tried different fuses. Was goingto start with a pick but thought somebody might have a cleaver way?
If you can a small pair of needle nose pliers can be used to squeeze the contact points together, or a small flathead or a pick. You can also slightly twist or bend the prongs on the fuse for a tighter fit.
My 2008 FLHT got very light coat of scale/corrosion on tabs of fuse,hardly visable. Caused loss of power to that circuit. put in new fuses coated tabs with die. grease and never had problem again. Even pulled all fuses on my 2013 FLTRX and coated the fuses.
That is a pretty good idea right there. A tube of the dielectric grease is handy to have and I use it quite a bit but never thought of that.
Good fuse holders and connectors feel pretty stiff and offer real spring action when made with proper materials. They also last forever, like WWII army surplus equipment!
Cheaper design fuse holders and contacts are often made of mild brass and tend to loosen then soften as heat builds up between damaged or deformed male-female parts. These must be replaced unless you accept to play Russian_Roulette.
Unfortunately dielectric grease is for corrosion protection of non plated contacts, it's a water repellent and cannot offer a safe and reliable contact. Repositioning contacts and fuses is only a temporary solution. When poor-contact problems arise with fuses, disassemble your fuse holder and replace the incriminated contacts. This is not an expensive repair and will keep you out of trouble.
Thank You… Solder worked for me. I had the same issue with a used truck I bought. The previous owner put the wrong style fuse in and the connection was not solid. I tried bending the prongs, aluminum foil, copper wire but this was what worked. I searched the internet and found you. Thank you again
