Please help me choose a MAP for 2006 Ultra
I am not familiar with choosing a MAP (I bought the cycle second-hand with the PCIII already installed, so consequently already mapped). I would like to check the existing MAP against what some experts on this board might choose. There will be no further engine modifications. Thank you.
Power Commander III
SE ported, CNC/HTCC Heads
95 cubic inch (SE) Screamin’ Eagle big bore engine
S&S 570G cams (gear drive cams)
SE Stage 1 air filter kit
SE roller rockers
Screamin” Eagle manual compression releases
Vance & Hines True Dual Headers and Ovals
10.5 HTCC Pistons
25-degree CVO fuel injectors
Power Commander III
SE roller rockers
10.5 HTCC Pistons
If you find a PCIII map for that combination it will be from a tuner probably. Not real common and not very many folks using PCIII anymore or at least making changes to them. If you are happy with the current tune, then run it. If not you may get help to correct a problem like popping or pinging. Sounds like a good setup on the cams and heads and other components.
Mordrapheus
07-03-2007 08:11 AM
