Mostly Free and Easy Horn Relo 2009 Glide
Old 03-07-2014, 01:28 PM
SCJE8's Avatar
SCJE8
SCJE8 is offline
Nice job...I like the clean look!
Steve
Old 03-07-2014, 01:39 PM
crimson13's Avatar
crimson13
crimson13 is offline
Nice job, cleans the motor up. Adds another "to do" to the to do list.
Old 03-08-2014, 09:15 AM
Bogash's Avatar
Bogash
Bogash is offline
For all the guys asking about sound. I tested it out yesterday on the freeway here in Dallas and got a cager's attention. I don't think it's quieter. It doesn't seem to be muffled at all.
Old 03-08-2014, 09:23 AM
Bogash's Avatar
Bogash
Bogash is offline
Originally Posted by mkguitar
Frank, removing the tank takes almost no time, the fuel line is a quick connect.
If the bike has been sitting over night, they will be no pressure in the line, so you will get maybe 1 drop of gas
pick a nice soft place to set it down, an emptier tank weighs less, so that makes easier.
don't let the prospect of removing the tank keep you from doing something good for your bike
OP, looks great- hope the dB's are able to project past that cover.
Horns usually need to have a mount with some flex to it- a solid mount seems to not works as well....i wonder how that works
I have a couple of radio shack piezos in that location ( at present) food for thought
mike
Didn't have to remove tank. The place I mounted it is a plastic piece with a little flex to it. I guess if it stops working I can pull it apart and put a rubber grommet between the plastic and horn stud, too...
Old 03-08-2014, 10:19 AM
keno's Avatar
keno
keno is offline
Clean look!
Old 03-08-2014, 10:35 AM
bigheadted's Avatar
bigheadted
bigheadted is offline
I love those cheap/free/easy mods !!
It does look nice and clean too.
Kind of strange too !
I am so used to seeing the old Cowbell hanging there it would take bit to get used to !
Old 03-08-2014, 11:42 AM
TeamMudd's Avatar
TeamMudd
TeamMudd is offline
there was a thread over in the Dyna section about "freeing the JUGS". i did it with my old street bob and i really liked the look after the mod. i installed the horn on the front of the frame, hidden away. i have been contemplating doing the same with the Classic as well.
Attached Thumbnails Mostly Free and Easy Horn Relo 2009 Glide-street-bob.jpg   Mostly Free and Easy Horn Relo 2009 Glide-street-bob-jugs.jpg
Old 03-18-2014, 05:02 AM
Kuz's Avatar
Kuz
Kuz is offline
Do you remember what color & what gauge the wires were?
Old 03-18-2014, 07:44 AM
Taildragger NC's Avatar
Taildragger NC
Taildragger NC is offline
Good job Bogash...This is going happen on my bike soon. Its threads like this that get the "flat wallet" bike owner's attention. Thanks
Old 03-18-2014, 10:28 AM
TeamMudd's Avatar
TeamMudd
TeamMudd is offline
if you're referring to the horn relocation.... the plug on the horn should have just 2 wires. on my old street bob I just made a pig tail harnes to extend up to where i located the horn.
I think i used 14ga wire (maybe 16ga) for the pig tail on my bob. made it about 12" worth. tucked the original harness back up under the tank and hid the pig tail to where you could barely see it.
it should be similar on the touring. i'm sure i'll find out here shortly! i put that on my need to do list!
Quick Reply: Mostly Free and Easy Horn Relo 2009 Glide
