I rubbed the Snake oil on and drank the koolaid !
If by design this is a cold plug, it can not ignite as well as a warm plug when needed unless a prolonged or forced series of sparks are produced. Once ignition occurred sparks can continue to be delivered until the next exhaust cycle without any effect, like on the Ford "T" ignition/vibrator coil
I had one of these coils when I was a kid!
been running car plugs in my 04 for years. Bike runs strong and no issues. 150K in miles and counting....
see cross reference here. I think they are around $1.50 at any auto parts store.
http://www.harley-performance.com/ha...park-plug.html
Stock style plugs last a lot longer too. I got a bucket of year old stock plugs and they are all still good.
Iridium type plugs have proven to give a "boost" in performance but the electrodes just don't last and they will fail long before stock style plugs.
In my opinion, risking failure on a long trip is not worth all that money but some (a lot of) people are obsessed with any power boost they can achieve. It's all good
Funny you said this as it had a little spark knock under load at lower rpm's. I just would downshift but I do not notice any spark knock now. hmmm?
A while back I bought some super duper flash-o- matic spark plugs, then changed my oil, then filled the tank with high test gas. I was chasing down Hyabusa's with just those simple changes. The horsepower and torque gained was unbelievable. It felt like I had a new bike!. Then the alarm went off and I realised it all was in my head.,,
I usually do not **** away my hard earned $ but for some reason just had to try these.
The plugs before were stockers with low miles on them and looked perfect. I have never had any issues with the HD plugs before.
Hack away at me all you want to, it is funny.
I knew there was a lot of controversy with these plugs or any different item or idea. I also ran Splitfire plugs in my fleet of S-10 pickups years ago and overall picked up a 2mpg average improvement. Spread that over a couple hundred thousand miles per year. I used to have the records but that was in the early 90's.
Nobody can convince me that those did not work, I even switched back to the stock ones for a couple months and put the Splitfires back because MPG dropped.
Beads in your tires !!! Goop in your tires !! No way you need to have ugly weights and have them balanced the way they have always done it, that stuff will wear out your tires from the inside or cause your wheels to rot.
Nitrous oxide? sprayed in the intake ?? haha.
I am sure the list can go on and on.
Too bad someone got banned for posting some Dyno results, it would have been neat to see them. I am usually pretty open minded to read and learn new things and on occasion to try them out BEFORE having a opinion on them.
I plan on pulling them once I take a couple tankful ride on one of favorite loops this spring, then swap back to OEM and do the same ride and direct compare the results. But for now I seem to notice and feel a little difference.
The pair was around 35 dollars.
I am not attempting to generate sales or anything, I just read all the controversy and widely varied opinions posted and finally decided to try them. I knew there would be a "witch burning" if I posted my own experience with them. I am not trying to convince anyone to try them, simply posting what happened with me and my bike. If they ran like crap I would have tried to post a fair and unbiased report and sent them back.
I wonder how many middle aged limp wiener erectile dysfunction sufferers have tried some kind of magic cream, supplement , pill or bought a mighty vac with a tube for your limp noodle issue that are not doctor approved, endorsed by the stodgy medical "profession" or accepted way of thinking? Bet there are thousands that have tried some out of the box thinking on that one. Post up your results here hahahaha
Enjoy the crummy weather reading !! Think I will go make a batch of green Kool-Aid and wait for the rains to stop to ride my better running bike. YAHOOOOO !!!
Received 49,910 Likes
I had a buddy who always used /tried the latest and greatest gadgets, gizmos and contraptions that would give him more power, more fuel economy and more whatever ... After listening to his "positive" responses to whatever he had done last ( always the "new and improved" worked ) I questioned him as to how he drained the excess gas that his scooter had to have been storing because every new trick got him better mileage and more power ... Just my .02 cents worth :>)
hey brother, it's your money, you can do what you want. i'm not gonna bash on you for it. i was just curious about the knock sensor. it is dependant on the resistance in the spark plug. is the resistance between the 2 different? what is the acceptable working range? who knows?
if you like the way they run, great for you. i'll just stick with the stockers myself.
