new brakes and rotors break in?????
Just put on polished rotors and new lyndal brake pads on the front. Prior to this my wheel spun freely when in the air. Now I get slight drag maybe a full spin if I spin it hard enough. They arent locked up or anything just a slight drag. Havent ridden it yet. Just pulled the brake lever a few times to get fluid back down to pistons after compressing pistons for pad replacement. Is this normal? Should I expect slight rub for a few miles.
Installed my new rotors and pads this morning. Slight drag when spinning the wheel as expected. Went for a ride and couldn't hear anything from the brakes and they worked great. Also replaced all of the brake fluid, front and rear. Now if I could just get rid of that annoying clunk the first time I apply the brakes after backing up I would be a really happy camper.
Received 4,632 Likes
I put the DNA solid polished superspoke rotors front and rear on my 2013 with stock pads...... Had the clunk, it went away, but I still have a ring, or humming sound when I brake. The rotor surface is a little galled now, but I expected that. Once this winter ends, I'm sure it'll all break in nicely.
