2004 rk brake fluid ?
Look closely!
You can't use either DOT 4 or DOT 5!
Must be what is in the cylinder.
Two different animals!
They do not mix!
Put the wrong stuff in and you'll have big time trouble.
Most riders don't change brake fluid as often as they should so you probably have what came from the factory.
That info would be in your owners manual and on the cylinder cap.
If working on your bike with changes, get a service manual.
The price for a SM would be less than the cost of fixing the problem of mixing DOT 4 and DOT5.
They don't mix!
It should be marked on the top of your brake master cylinder!
Look closely!
They do not mix!
They don't mix!
Look closely!
They do not mix!
They don't mix!
Especially the part of most riders not changing brake fluid. As I recall, it should be done every 2 yrs. Brake fluid does collect moisture over time, which leads to brake fade and failure.
Your 04 came from the MOCO with Dot 5 in the brake system. It is a purple color and does not mix with any other brake fluid. Harley thought it was a good move but after a few years they found that Dot 5 has some bad things with it. The Internet is full of reports on Dot 5, do a search as I did.I decided to change my 04 RK to Dot4 which Harley went back to by the way. You should flush and clean all of your brake system when doing this. I changed my lines to the SS with PVC liners to get better brakes. The factory lines will wear after a few years and when you apply the brakes the line will expand instead of using all the pressure to the caliper. This results in less brake control. I think that all bikes should come with the stainless lines.You will improve your braking performance by leaps and bounds. Later Fairshake
