Installed an air horn today
Today I installed a Steibel air horn to replace the whimpy stock horn. Bought it on EBay.
Turns out the horn has a bracket on it that holds the factory nut and allows you to get the nut close to the rubber isolater, the slip on the horn and rotate the horn until it's really tight.
I'm thinking I may put some locktite on it just to be safe.
It doesn't look bad to me. Hardly noticeable. Here is a before and after shot.
It also came with a relay, per the service manual there is no horn relay in my factory wiring so I will install the relay later.
Overall about a 3 minute install except for the relay.
I will say, it's very loud, easily twice as loud as the factory horns. Between this and my loud pipes I hope to get people's attention when I want to.
you SHOULD use a relay.
the compressor for the air horn draws more current than the stock horn.
while you may not have trouble next week, over time the contacts in the horn switch are likely to arc and pit, leading to failure.
the relay takes very little time to install, pull the tank.
my first air horn ( howie) worked for a short while then turned into a sick cow
currently running the HD- which I bought from a forum member stripping a wrecked bike- better than average fit and finish, exacting instructions- retail cost is stoopid.
I run a 6 volt horn on my FXRP, loud as heck...don't lay on it, flames'll come out!
mike
mike
mike
mike
You will notice a difference too on performance. Easy to do.
It was $34 on Ebay, it's nice that it was designed to basically bolt right on.
Here's a great link I just found.
http://www.rattlebars.com/avalanche/relay_basics.html
I may run a relay later...frankly I have never used the horn before on my bike and don't really plan to now. Although, it is fun to blow that loud horn so perhaps I will do it more often now and if I do, then I'l run the relay.
