Starter Question
Starter Question
I ride a 2010 FLHTC-U which is stock and has 16,800 miles on the clock, all put on by me. Bike has been trouble free, but I now have a concern. You Experts can probably quickly tell me what may be wrong.
Engine starts up from cold as it should. Sometimes lately (last 500 miles or so) when I try to start a WARM engine, the starter must be used for several seconds, sometimes up to 10 seconds. This is NOT normal, and someone told me that it might be part of the Compensator problem. Want to have an idea of whats wrong before I go to a Dealership service department, and Daytona is fast approaching. Perhaps I should have named this thread: Starting Trouble. The starter seems to be doing its job, it just has to crank the engine longer than normal.
Any ideas? any advice is appreciated in advance!
OP said nothing about strange noises and a starter clutch or weak compensator make quite audible noises. I would think in terms of a drippy fuel injector causing too rich a mixture during a hot start. Try an immediate start after turning on the main switch before the fuel pump has a chance to fully prime the system. If that seems to be an improvement you might run a fuel injector cleaner through the next couple of tank fulls of gas. See if more normal starting returns. Sometimes I have to open the throttle while cranking also. New injectors run around $80 to $100 EACH from Harley and after market ones seem to be even more expensive. Good luck.
paco ritter
05-07-2009 02:34 PM
